slammedresto
How many inches is a 1 spline drop??
and how many is a 2 spline drop??
Joval said:Which doesn't look right either, aren't outers for coarse adjustment?
Johnny said:Joval said:Which doesn't look right either, aren't outers for coarse adjustment?
any mathmatical proteges work it out? or can we find a chart for bays?
if outers have more splines wouldn't it be fine tuning?
stagger lee said:when i lowered my van i wrote a document explaining all this etc. i can pass it to you if you want? the values are measured as very very close approximations, measured as best as i could. but...
early van; 44 inner plines, 48 outer splines.
therefore; 8.18 degrees rotation per inner spline and 7.5 degrees rotation per outer spline.
torsion bar to hub centre-to-centre i measured at 445mm (spring plate distance).
therefore; 63.3mm drop per inner spline and 58.1mm drop per outer spline.
fine adjustment, counter drop, i.e. 1 inner spline counter acted by 1 outer spline gives 5.2mm drop.
hope this helps some?
Joval said:stagger lee said:when i lowered my van i wrote a document explaining all this etc. i can pass it to you if you want? the values are measured as very very close approximations, measured as best as i could. but...
Yay. Sticky this![]()
