Hi all, have fitted a new wheel and painted everything else incl ignition housing, column sleeve and indicator housing.
But now I have put it all back together and mounted it to the dash there seems to be slightly too much play between the ignition housing and the steering column? so if you grab hold of the ignition housing you can move it up and down the column a few mm either way.
Should they be bolted together somehow to stop this? or do they all move a touch?
Any help would be great as i want to get it back on the road and dont want the MOT failure :shock:
