Milky
Hopefully going to the Slough swap meet on Sunday 14th and have a few spares i can bring if required !.Will put list below and add more once i have sorted out exactly what i have.All are for Bay window.
1.Type 4 engines .Both are 2 ltr engines and ideal for rebuilding.£100 each ONE SOLD
2.Type 4 fuel pumps £15 each
3. Type 4 alternators SOLD TO Bluecab
4. Type fan housing and flaps £15 .Also fans £10.
5.Type 4 tinware approx 9 pieces in total £50.
6.Bay wiper motor £10
7.Type 4 engine tin between pushrod and cylinder heads. £8 each
8.Type 4 thermostat housing and cable.Thermostat is there but its U/S. £7
9.Type 4 oil cooler boss.This bolts to engine and allow for a remote oil cooler to be fitted. £5
10.2 ltr heatexchangers.In good condition. SOLD
11. Joiner Pipe between heat exchanger to heater pod.Galvanised and in good condition. £15
12.Passengers seat back metal hoop.Hold seat in position. £3
13.Two standard late Bay wheels.Rusty and require a blast clean. £5 each
14.Alternator wiring loom. £5
15.Type 4 distributor. £15
16.1800cc gearbox front mounting [u-shaped rubber and metal loop bit].No longer available new. £10
