Leaky doors
chrisritchie
Jun 18, 2008
107
Hi, my name is Chris and I have a 1970 Westy with a leak! Someone had taken off the plastic from behind the front door cards, and I want to know if you can buy a replacement. I've cut up a plastic dust sheet and stuck that up for now. Thanks for any help!
Sounds like you've done the right thing,using some plastic sheet and sealing it all the way around should be just the job.
I used the plastic membrane from b and Q in the laminate flooring section.
£12 buys enough to do about 5 vans and works a treat!!
Realy thick , actualy a bit thicker than original.Just cut it to size, stick or tape it on, and be sure to seal it around the edges and bye bye leaky doors! :lol:
