LHD or RHD beam....
thru_a_lupe
Feb 7, 2008
1,215
3
'the shire'
.....what are the implications of using a RHD beam on a LHD bus?!?!
im presuming the mount for the steering damper will be on the wrong side?!? anything else?!?
cheers,
jon
The steering box is on the front chassis so that won't be affected.The only other thing which can be affected is a servo mount if you have a servo that is,Not many early bays had them as standard.But like the steering damper bracket it can be cut off and re welded to the right place.
Your 1970 bus shouldn't have the servo bracket fitted if it's standard brakes.
