starbiscuit
My 1970 bus is missing relays and the fueses / wiring is a mess.
I can sort the wiring, but I would like to replace the relays with ones that fit the fusebox, rather than mount different ones elsewhere.
I have found DNI 0127 and some Hella equivalent numbers, but they are equivalent to 411941583B, which is off a later bus.
http://www.dni.com.br/dni2/index.ph...&category_id=2&option=com_virtuemart&Itemid=1
1970 should be 411941583.
Does anyone know what is the difference? Are they interchangeable?
(Both are able to flash the lights when the light switch is off with terminal 30)
Thanks for reading,
Rob
Thanks for reading,
Rob
