stuif Well-known member Joined Sep 23, 2009 Messages 287 Reaction score 0 Location Holland Mar 6, 2015 #1 Is anybody running Monroe airshocks at the rear ?? I can't get much lift, even on 145 psi Right side about 3 cm Left only 1 :evil:
*Sam* Well-known member Joined Dec 25, 2011 Messages 2,301 Reaction score 0 Mar 6, 2015 #2 Mycha was running them.
stuif Well-known member Joined Sep 23, 2009 Messages 287 Reaction score 0 Location Holland Mar 6, 2015 #3 I think he was running Gabriels
*Sam* Well-known member Joined Dec 25, 2011 Messages 2,301 Reaction score 0 Mar 6, 2015 #4 He started on Monroe's but changed to Gabriel's because the bag is enclosed in the metal sleeve of the shock body. They are also 200psi rated instead of 180psi ? for the monroe
stuif Well-known member Joined Sep 23, 2009 Messages 287 Reaction score 0 Location Holland Mar 8, 2015 #5 Problem solved Changed the angle of the shock and leveled left and right by adjustable springplates. Now it raises about 5 cm
mr scoops Well-known member Joined May 8, 2010 Messages 1,144 Reaction score 0 Mar 8, 2015 #6 Have you simply replaced the stock shocks with the air units? How did you change the angle they are fitted?
stuif Well-known member Joined Sep 23, 2009 Messages 287 Reaction score 0 Location Holland Mar 8, 2015 #7 Yes replaced them and with compressor pump them up. On the top mount i cut some metal from the mounting point (if it makes any sense)
mr scoops Well-known member Joined May 8, 2010 Messages 1,144 Reaction score 0 Mar 9, 2015 #8 Have you got any pics of the area?
