New jacking points and outriggers
Belly pans for both sides will help to stiffen the chassis to a degree given the torque this engine will put out and how hard the owner will want to push it into corners!
Donor chassis front section had to be sourced to replace the poorly repaired and rusty original section
Red9Design front end and brakes will provide the front suspension and braking duties
Hydraulic clutch conversion
Ride height will change a little but this gives you a rough idea
New rear pillars
Tight squeeze but we managed to slip it in
Will be retaining factory heater system, air box, air con etc etc to make life easier with the Porsche engine - learning from experience, the more modifications you make, the more teething problems you have!
17in Fuchs with no dish just didn't look right on the rear
