Loxy
The Plan:
After going through my spares I carry in the bus, I decided to fit a NOS Halfords purchased Lucas 4500 RPM rev limiting rotor arm that was in there just to see at what point it cut in (out) and whether I had been driving the bus too hard.
The Details:
Engine is the original 1600TP totally stock other than a Turbo Thomas Stainless header & Turbo muffler & pertronix ignitor (vacuum advance dizzy), never rebuilt 52000 miles on it, stock gearbox (CE? code)
Bear in mind that I have 175/65/14 front tyres (~10% smaller than stock) and stock tyres on the rear - all readings taken from speedo.
The Results:
when I used to change up a gear (both before & after exhaust swap):
1st - ~10mph
2nd ~30mph
3rd 55-60mph
4th usually stick to ~65mph except for overtaking
4500 RPM limits
1st - didnt try it (will try later)
2nd cuts out at 31mph
3rd cuts out at 52mph
4th still going strong at 72mph
The Outcome:
I guess from now on I will have to re-adjust my gear changing from 3rd-4th!! as it appears I was giving it a bit more than factory spec stick :shock: I'm also going to take the GPS on a drive next week to get some more accurate figures.
Questions:
Does anyone know how accurate the rpm limiting rotor arms are (still waiting for my tacho to turn up - thanks Royal Snail).
What speeds do you change gear at in your bus (what engine/gearbox)?
The Details:
The Results:
1st - ~10mph
2nd ~30mph
3rd 55-60mph
4500 RPM limits
The Outcome:
Questions:
