I've just started doing mine and I've started off with the pop top. I've got 25mm of celotex nailed up there with that very fancy named adhesive called 'Sticks Like ****', I thought I'd cut the celotex halfway through with a circular saw then bend it around the curve of the late Devon pop top I have. Imagine how delighted I was when I cut a prototype from the off cut to see whether to put the cuts on the inner or the outer surface and the cuts are now facing the interior because it naturally bends that way when you cut it half way through with a circular saw, a real bummer though if you wanted to keep it flat I spose. So that's the start and the largest are and I'll gradually work my way through the bus. As I come over the slopy bit of the engine bay, I'm toying with the idea of routing it out to get it down tight on the ribs, and that should make a large noise reduction too.
Ozziedog ',,,,,,,,, snug as a bug in a rug',,,,,, maybe. :mrgreen:
