removing spare wheel mount from front panel
Wishart
Sep 25, 2007
232
Northampton
when i remove the spare wheel and mount from the front panel, what am I likely to be left with?? Big ugly holes?? Im guessing they wont be positioned in the same place as the holes for the front badge?
Ultimately, I want to put a badge back on - am i gonna have to weld these or fill these up?
Hi!
Mine had a spare wheel on front, i think they are suposed to fit in the same 4 holes as the badge, unfortunately the previous owner had fitted mine with a mixture of plaster board cavity fixings, and around 12 extra holes drilled for good luck, and pop riveted. :roll:
Luckilly for me, ost of the holes are hidden by the badge, the otherr i just filled with some or just sealent for the time being. Maybe you could fine some small bungs to save you having to weld up.
Good luck!
Alistair
I found the holes to be the same but were bigger, so I made up spacer to reduce the size and glued it in place then used the normal fixings
