Shopping list, advice
Webbaldo
Mar 11, 2014
756
How do, I'm about a month away from getting to engine build up stage, so thinking about what parts Ill need. I've built up plenty of A-series/pinto engines before but not aircooled, plus I'm absent minded as hell :lol:
I'm not on about fettling etc just bare bones actual bits.
I have a new longblock off VWH so what else will I need that I've missed?
I have: -
Long block engine (with oil pump, pressure switch, plugs fitted)
Carb (well to rebuild)
Exhaust - soon to have heat exchangers as well
Inlet Manifold/seals
Tinware/tinware screws
Air filter
Dynamo with pulley
Fuel lines
Tinware to body seals
I need (think):-
Dizzy/Cap/dizzy drive etc
HT Leads
Coil
Clutch
Bottom pulley and belt
Oil (obviously)
Fuel pump (cheers monkeyvanwestybike !)
Anything obvious I've forgot?
Are you thinking full flow in which case pipe work, filter and filter mount/fittings.
I can supply you with a nice ignition kit and Vintagespeed exhaust if needed, on me.
Dan.
