T’Haus Flipped Spindles / Coilovers
Sharp69
Aug 29, 2019
14
8
Hi all,
I think I know the answer to this already but just wanted to put it out there in case anyone is running this set up and can give advice.
69’ bay running a standard beam, I’ve just installed some T’Haus flipped spindles and I’ve come to install some GAZ coilovers.
The coilovers foul on the beams bump stops, I was hoping to keep them but I can’t see any way other than cutting them off or clearancing them?
Is anyone running this set up?
Hi Chris,
I guess these are the ones I sent you? If that's the case, my bump stops had been cut off.
Russell
Hi Russell,
Yes they are and thanks again! Took me a while to track down the locking trailing arms but got there in the end!
Bugger, looks like the angle grinder is coming out then!
I used a small spacers on the bottom of mine, worked fine. i seem to remember the GAZ eye isnt as wide as a stock shock, so it gets pulled over towards the bump stop when you do the nut up. I didnt like the shocks, and have gone to uprated stockers from jk, much nicer ride.
I had to modify my back plates as well, but mines a disc front end. I still get rubbing though, apparently most people remove them completely
