The Wrong Carb ?
Stirlingmoz
Aug 15, 2007
296
Woking
I picked up a Solex Pict 3 34 carb at Slough which is in need of reconditioning.
I compared it to my Bocar carb this afternoon and noticed the vacuum pipe for the distributor is blanked off.
It looks like its been like that from new.
Have I bought the wrong carb ?. Was this intended for another model.
Can a vacuum outlet pipe be retrofitted ?.
Just exploring my options. :?
I guess it would make a cool paperweight !
Your thoughts are most welcome
Stirlingmoz
Is it possible to drill the opening and use the vac take off from you old carb?
I guess you would have to drill slightly undersize to get a press fit.
Ian
I could probably do something but this seems to have been blanked off at the factory.
I was wondering which vehicle would use as standard a non vacuum distributor.
Is it correct that all standard VWs use a vacuum distributor and the 009 style with centrifugal advance is aftermarket ?
Stirlingmoz
The 009 was never fitted by VW. All engines use a variant of either a vac only or SVDA depending on the age and VW's attempts at emission control.
