VW engineers didn't design & fit the thermostat system for fun. They are to allow the engine to warm up as quickly as possible and then to control the engine and oil temperatures. Don't forget, most engine wear takes place when the engine is cold. Would you take out and discard the thermostat in your daily water cooled run about?.Delete flaps and stat. They are only useful in an artic zone. The engine always warms up quickly enough in our moderate zone. I have a 912 Porsche engine in a beetle and a T2 van 1600 and both are flapless and never have a problem. In the fully warmed up condition they are open anyway. When Beetles were daily drivers I could see the logic why VW installed them for cold days and US emissions. I drove a beetle with no flaps on cold days and never had a warm up problem. Save your money and spend it on an air freshener!
Hi, do you have a thermostat left and how much do you want for it, thsnks … if you do.I have two thermostat and brackets but no flaps,
Definitely. The Mexican ones are ok until they fail. So if anyone reads this that doesn’t know, when they fail, they fail closed! What a bright idea that wasEven without a thermostat and the flaps in an .open. position, they direct the airflow correctly. Worth having I'd say.
The water cooled system has no comparison to how air cooled system functions. Air cooled is direct cooling by a fan with oil cooling assistance and the flaps do not have a control function. As I described earlier the fan is the only device for cooling with increased engine speed giving increased air flow. Water cooled engines use a liquid which is the primary medium in engines transferred by a pump through an air cooled device called a radiator which ultimately cools with the aid of a thermostat and other additional devices. If you rely on VW engineers to support your thesis remember that these same engineers designed a diesel cheat system and that definitely wasn't fun for VW!didn't design & fit the thermostat system for fun. They are to allow the engine to warm up as quickly as possible and then to control the engine and oil temperatures. Don't forget, most engine wear takes place when the engine is cold. Would you take out and discard the thermostat in your daily water cooled run about?.
That should not happen as they are designed to fail open.Definitely. The Mexican ones are ok until they fail. So if anyone reads this that doesn’t know, when they fail, they fail closed! What a bright idea that was
The original bellows type fail open, but i think you'll find the mexican type fail shut.That should not happen as they are designed to fail open.
The flaps do have a control function even if a thermostat isn't fitted. They funnel and direct air over the heads and barrels.The water cooled system has no comparison to how air cooled system functions. Air cooled is direct cooling by a fan with oil cooling assistance and the flaps do not have a control function. As I described earlier the fan is the only device for cooling with increased engine speed giving increased air flow. Water cooled engines use a liquid which is the primary medium in engines transferred by a pump through an air cooled device called a radiator which ultimately cools with the aid of a thermostat and other additional devices. If you rely on VW engineers to support your thesis remember that these same engineers designed a diesel cheat system and that definitely wasn't fun for VW!
Not the same engineers though, about 60 years apart !.The water cooled system has no comparison to how air cooled system functions. Air cooled is direct cooling by a fan with oil cooling assistance and the flaps do not have a control function. As I described earlier the fan is the only device for cooling with increased engine speed giving increased air flow. Water cooled engines use a liquid which is the primary medium in engines transferred by a pump through an air cooled device called a radiator which ultimately cools with the aid of a thermostat and other additional devices. If you rely on VW engineers to support your thesis remember that these same engineers designed a diesel cheat system and that definitely wasn't fun for VW!
Yes got one left, thermostat, powder coated bracket and connecting rod, £45.00 plus postageHi, do you have a thermostat left and how much do you want for it, thsnks … if you do.
