i bought a 2nd hand engine with them on which only ran on 2 cylinders and was finally traced to the carbs being at fault.The cheaper versions are renowned for distorting.With the top of the carb bolted down you could feed quite a hefty feeler blade in either side,which was cured with a bit of flat filing and 2 gaskets! so check before you buy
