Having some troube trying to get my westy tap working. Will it only work with a electrical supply to the pump? Or is there some way it can be operated manually?
Will post some pics up tomorrow if i have time. It has a lever on the tap unit but also a switch connecting to a electric pump in the water carrier itself. Is the pump standard for a westy?
Given the year it's originally annual pump and if PO has added an electric pump gonna be a switch somewhere.
Probably need t prime the tap by filling the plastic bowl bit under the tap with water before it will draw water up.
