Clutch cable route from front..
Rhd- can’t seem to get tension on the clutch. Think it’s not routed properly. Back end at gearbox is all good. 🌈👍
Cheers for that …. but need a good image of the route at front- from pedal to conduit.
This last one clearly shows a vacant grommet through chassis- although this is not in line with the conduit that carries the cable through to the rear. Is this the route it should take???
Any help is appreciated 🌈👍
    1.9 MB
So checked depth of bend on outer cable (not the easiest thing to do) anyways all good there.
So wound up the adjuster on the cable and finally got feedback on the pedal !!!
Now hopefully adjusted up properly 🙏
Seems it was just my interpretation of what feedback on pedal feels like.
Bloody driveway amateurs again !!
I'm about to attempt to change the clutch cable conduit on my rhd 1972 which suffered damage. I have a new tube which is straight!! So going to think carefully before I start
