1700 1800 or 2000cc ?
vwcamper
Active member
Sep 4, 2009
29
How do you tell the difference between a 1700cc 1800cc and 2000cc type 4 motor? I am thinking of buying a 72 bay and the owner says that the engine is a 2.0L , but the v5 says 1679cc
get the engine code off it and cross ref here
http://www.thesamba.com/vw/archives/info/engine_letters.php" onclick="window.open(this.href);return false;
Hi, The number starts with CU and on thesamba website it says, CU 1980-1983 2000cc - Vanagon style. So i guess the engines from an 80's volkswagen ??
a picture would be good, to fit a T25 engine in a T2 is a fair job, the tinware isn't the same, i suppose it could just have a CU block but seems unlikely.
A goiod exhaustive list of engine codes :
http://www.volksbolts.com/faq/eng-codes.htm" onclick="window.open(this.href);return false;
CU is a 2.0l engine from a T25 Vanagaon.
Sounds like they have exchanged engines but not updated the V5...naughty.!!
Sounds like it had a1700 type 4 engine in that has been changed to a 2.0 type 4 engine, other than the engine number there's not much to see that's different
AN code
1800 93 66 1795
914 / 412LS
85 HP
F.I. or Twin Carb
hmmm interesting, got a picture
its on the data in the link about 12 down from the top
so looks to be either a porsche 914 engine or a 412ls
Alex VW Heritage said:
mattyd72 said:
sparkywig said:
Engine code will tell you what it started life as.
CK, CL - 1700
CM, CN - 1800
CP, CT - 2000
Mines a AN....:eek:
Sent from my GT-I9100
You sure its not an AW (1800 from 73?)
davidoft said:
AN code
1800 93 66 1795
914 / 412LS
85 HP
F.I. or Twin Carb
Bang on. Its from a 412ls did have 40 pdsits now on dells.
The proper big valve 1800 heads. :cool:
