Vw speedshop 2.5" stainless steel exhaust muffler.
Currently attached to large flange 4 into 1 header (not stainless).
Stainless reducer cone also included, so it can also fit a small flange 4 into 1 header.
Exhaust wrap, various clamps, gaskets, nuts and washers.
Stainless muffler support bracket.
£150.
Located in Sheffield, plus regular trips down the M1 to J15 & the Midlands.
I can also bring to Techenders 27-29th April 2018
The 2.5" stainless exhaust has been extended with a mild steel tube with a threaded hole for lambda sensor.
This could be cut off and replaced, with the included Stainless reducer cone and flange (then it could be fitted to a small flange 4 into 1 header).
It has been fitted to a late bay camper with a type one engine with heat exchangers. Could be modified to fit other vehicles.
The stainless exhaust muffler needs a good clean to shine!
£150.
![152f43952ada615d3aab3e2dae7b192d.jpg](https://proxy.imagearchive.com/e27/e275fb2f67def88c6b3bb94c20eca3a4.jpg)
![5cb2c6f11b1faa075af8e05bd6a65970.jpg](https://proxy.imagearchive.com/27e/27e230af0aa4dfb3907b40b4e1195dfb.jpg)
