When parked up what is the minimum psi level for air shocks? Do you let all the air out down to 0psi, or does the bag on the shock need to retain some level of pressure to stop it breaking? I am only talking about being parked up, not driving.
Who sells the front air shock kits as I'm just wondering if it's best still for me to buy from volks projects in the Netherlands as the UK seems limited
I sell high pressure air systems and it generally concidered that if it is meant to have air onto it then it should even if not in constant use. as seals and springs and bypass valves etc. work best if they have a "maintanance" pressure on them if not the full working pressure.
