Doris
as above really chaps, couple of springs broken - is it just a case of putting a blob of weld at the break to rejoin it? if not what next?
Cheers - Rob
Cheers - Rob
Doris said:I was thinking about this last night & thought about those brass connector block used for heavy duty wires? I could cut a little recess in the end of each part of the broken spring,then put each end of the broken spring into the brass connector block,tighten down the screws into the recesses to hold it.....think that may work???
