andewilson
tried to remove my ols floppy ball joints yesterday. 6 tonnes on the press and they didnt budge an inch. what do peole on here do to remove theres
-tipi- said:You might need 'some' heat. One way is to cut the joint open, take out the ball/bolt and weld a big bead inside. This usually does the trick, and old joint drops off with a gentle tap of hammer. Like this:
http://www.youtube.com/watch?v=PZLxPyRdAbY
