- Joined
- May 22, 2009
- Messages
- 519
- Reaction score
- 2
Tried to fit my calipers on my Red 9 Wishbone setup today and think I may have the wrong flexi pipes and interested to see what others have done for the brake bracket where the flexi meets the solid pipe.
I had to cut off the OG bracket as it fouls the Red9 setup and it comes with a bracket as part of the top wishbone mounting. But if I decide to drop the mounting lower I don't know if that will work as the solid pipe will be connected to the wishbone mounting that will rise/fall? I probably should have welded new brackets to the chassis but its all painted now so too late.
The flexi pipe I was advised to use is for a split, the male end screws into the caliper but it bottoms out before a copper washer would seal it and the male end of the pipe curves inwards slightly, as if to fit a solid pipe. The caliper fitting looks like it requires a tapered style end on the thread if that makes sense.
Here's a few pics, hope someone can advise.
