mginty
- Joined
- Aug 1, 2008
- Messages
- 381
- Reaction score
- 1
- Year of Van
- 1970
- Van Type
- Dormobile
So I'm still in the process of rebuilding my front brakes, got the parts just lacking in time! I've stripped them down and got new flexi hoses/ backing plates & cylinders.
I'd like to check on a few things from you good people who know what you're doing (unlike me!)
Re-assemble:
a) fit new flexi hoses
b) fit new cylinders & old connecting line to new backplates (is there any tips for getting the cylinders mounted to the backplate as I'm struggling to get the bore through?)
c) refit all of this back to the steering knuckle
d) reattach the brake shoes, springs and adjusters (using copper anti-seize on the adjusters)
e) refit bearings/ drum.
----when refitting the bearings & drum should I clean out the old grease and add new?
----also given I'm replacing the backplates, I was going to paint the outside of the drum using some VHT paint. Any recommendations?
Final thing is I think I knackered the rigid pipe on the nearside so guess I'll need to replace that (see pic below). Is that just a case of unscrewing at the other end - 'T' connector(next pic below)?
many thanks as always!
Re-assemble:
