Dal
I don't know what the hell I'm doing wrong but cant get my brakes to bleed.
She's a 72 xover with the servo and a compensator. So give you a brief history shes a dry import that I bought with the brakes not working as reservoir empty, filled up the reservoir and soon found out the master cylinder was leaking as has a small hole in the casting, so bought another master cylinder fitted up and renewed the reservoir to reservoir pipe, but she wont bleed (dry as a bone) :shock: :shock:. The fluid is going somewhere as filled the reservoir again but we did try for about 2 hours.
cracked open the nipple on the compensator to see if that was getting fed but no joy there either
Anyone got any ideas and no there is no fluid leaks
