Carb Replacement
mattd1984
Mar 8, 2009
2,473
Langford
I've got a Solex 30PICT - 1, im running 1600sp stock setup. What would be a good replacement carb as mines leaking fuel? Or anyone know where i could get a good re-con unit?
could be worth contacting "bugjulie" on here or on Vzi (uses same name)
he rebuilds solex carbs & has plenty of happy customers
he might have one ready & could do a straight swap :D
mattd1984 said:
Matt_B said:
Twin 34ICT Weber's
Can you run twin carbs on a single port?
Yes, as long as you can find suitable single port manifolds - iirc you can get them for 34ICTs & for dellorto drla/weber idfs - look on here for an early "kombiporsche" post pretty sure he has drlas on a single port ;)
My mistake he had kadrons on single port manifolds:
http://forum.earlybay.com/viewtopic.php?f=2&t=10774&p=99132&hilit=+single#p99132" onclick="window.open(this.href);return false;
Hiya Matt,
1600 single ports came with 30PICT3s from the factory. A rebuilt Solex 30PICT3 would be your best choice if you are looking at a stock type set-up. A Solex 30/31 (also rebuilt) would be a second choice. A new Bocar or Brosol 30/31 would be a distant third choice.
