HI Guys,
Just thought Id run this past you lot and see if any one has any ideas..
Running std solex carb (single adjustment screw) which I reconditioned with new gasket set etc.. when I did engine last year. I aslo decoked the heat risers
Now the bus runs sweet as a nut on the move and It starts on the button. Its just to get her to idle I have the screw that faces you as you look at the engine screwed all the way in flush with the arm. You would expect it to rev its tits off because of this but it doesnt. When its warmed up fully it does idle a bit high - If I back it off it cuts out when driving when the engines cold after the choke has come off.
I`m thinking of buying a new carb - it seems that theres mixed opinions about the new EMPI/BOCAR ones?
I think I will get hold of a good used carb of known quality and try it. If anyone in the camb area has one for sale/loan that would be good.
Does anyone else have their idle screw all the way in? Is this masking a fault elsewhere within the carb?
ANy ideas would be greatly apreciated!!
