wil
Active member
Hi all,
I have a 71 early bay running a stock 1600cc. After fitting twin carbs I had a host of problems chasing from one carb to the next with very small amounts of dirt causing the problems. I fitted a filter king in the engine bay (stock filter above gear box too) so I could see what was happening & it became quite dirty quickly. I thought the filter king would stop any dirt that the stock filter couldn't.
After running out of fuel on a trip I refueled with the can of fuel I had in the van (Fuel gauge has stopped working too) but nothing came through to the filter, after some vigorous rocking of the van some fuel came through. I thought that the tank would need to be replaced so I set about removing the engine & fuel tank. Now the tank is out it appears to be rust free but i can see lots of small 'bits' on the base of the tank. I also had those brocket(?) balls in the tank which I have now taken out. What else could be causing this? Have i filled up somewhere with dirty fuel? The main filler hose from the cap to the tank will need replacing, maybe this has been deteriorating & depositing bits into the tank.
I really expected to see a lot of gunk in the tank after the refill wouldn't come through but it doesn't look that bad.
Anyone here cleaned out their tank? What did you use? Is there any filters/mesh in the tank that need replacing?
Thanks in advance
Thanks in advance
