dropped door
Oslo_mark69
Nov 11, 2009
461
Blackwood
My drivers door has dropped and as i can see , it has movement on the door side of the hinge inside the door .
Any tips on how to rectify this problem
If the door is moving in relation to the hinge you may just need to tighten the bolts.
If the section the hinge is bolted to is moving then it will need welding.
If you cant see precisely whats moving from outside then remove the interior trim panel and use a light/torch to identify whats moving.
If welding is required then you may need to remove the door.
