AGC
I asked for advice in a previous post about my indicators not working...To cut a long (and frustrating) story short I changed the Indicator relay and the indicators are now working However, now that I have put everything back together again I have another problem
Everything seemed to work fine until I returned home after a short test drive. When I turned the ignition key off the engine continued to run. When I removed the key the horn sounded and continued to sound until I replaced the key :?: :?: . I had to stop the engine from running by stalling it. When I removed the key the horn started again but stopped if I turned the steering wheel....The ignition light stays on even with the key switched off and removed so I have had to disconnect the battery..... HELP :x :x :x
