Can someone please help! I've just build my new engine with all new parts and with no fly wheel or shims or even a front pulley, I have about 1.5mm of end float. Is this about right or do I need to strip it all down and start again!
Until you've fitted the 3 shims and flywheel and torqued it you'll not know your actual end float which should be 4-5 thou, if it is out you can change the shims for different thicknesses until you've sorted it
