Forsale: early bay front disc brakes (full Unit)
G
Guest
Guest
Basically everything that unbolts off the front trailing arms. Its one unit the spindle, caliper, disc backing plate.
I replaced them with later bay brakes for easier maintenance.
They are in decent enough condition, discs are straight, although the drivers side would need some work to loosen it and the pads need replaced and a new retaining spring for the caliper as i broke it checking the pads, there are a few chisel marks as it was stubborn coming off the ball joint but only superficial.
I believe these are hard to find and expensive if your buying secondhand. (some one mentioned in the hundreds just for the caliper alone).
All you have to do is bolt these on to the ball joints.
Both sides for £200, collection prefered. I will post but carriage will be expensive as these weigh alot, i can check the postage rate if you need them sent.
I can post images if anyone is interested.
Johnny
are these wide 5 or cross over early bay discs ??
picture would be nice...
oh and where are you.........
Can't answer the other questions, but I do know Johnny is in Northern Ireland :wink:
