Pete B said:The cauldron has been bubbling away this evening!!!
Going to give it overnight to 'ferment' then freeze so as to defrost whilst travelling ready to just heat through Saturday evening.Has got Aarons seal of approval on the flavour stakes, as said will provide hot sauce for those wanting more fire!
Fairly busy morning coming up, adjust brakes, swap steels for Empi 5's, grease front end, plugs/points tune up, clear out crap from interior, check driveshaft bolts torque, down to local bike shop for 'urgently needed' new handlebar grips for Aarons bmx :roll: then to opticians to try his new specs.... breathe in then lunch and pick up Dad for meeting at Mums nursing home at 2pm. So much going on, am really looking forward to this coming weekend and having a bit of a breather. And lots of Witcap![]()
bluebay said:08.20 train Sat morning.
Pete B said:bluebay said:08.20 train Sat morning.
Not certain what time the cruise will leave the 'bonjour' services, but thinking probably about 10am local time?
If you are on the 08.20 that means getting off the train about 09.50 or so local time (1hr ahead).
If the cruise has left, the first stop will be at 'Nieuwpoort' services for a re-group and re-fuel. Take a look at the map and Nieuwpoort is clear to see whilst heading north on the A18/E40.
Don't worry mate, I'm on the 8.20 train too and I'm sure there will be plenty others!bluebay said:Pete B said:bluebay said:08.20 train Sat morning.
ok thanks for the heads up Pete,will just go with the flow and see what happens.Hopfully will get there in time before you all leave.
Phil.
