G
Guest
Guest
thru_a_lupe said:cqan someone please explain basically how this works?!? :?:
it sets up a 'geofence' around your bus and if the bus moves outside the zone the sim sends GPS coordinates to your mobile pinpointing where the bus is, if the GPS doesn't work (ie. in a garage) then it can use GSM mobile masts but not with the same accuracy.
You can input the co-ordinates into a map program this one i think is optimised to google maps. I have google maps on my android phone so could use it as a mobile tracker to find/locate and kick the s**t out of the thieves
you can send a ping at anytime using your mobile to ask it where the bus is. there are a shed load other functions not sure if they are on this one where its hooked into an ignition relay and can remotely shut the engine down.
The really cool **** is you can listen to the thieves as there is a built in mic that sends to your mobile lol
How does it work?
It uses GPS satellite signals to trace your vehicle.It can get your vehicle's real time precise position from the GPS satellites,and GSM sends the position information to your phone or the positioning platform.
With the position information,you can see the exact location on Google map or Google earth.Or,you can watch history and live work status on the positioning platform. You can choose the Positioning Platform in your country by yourself .
More Value Functions:
Cut off oil and circuit. If you find that your vehicle is stolen, or left your authorized area, you can send SMS to cut off the oil and circuits, so that vehicle stopped running.This means Remote Controlling Oil and Circuit.
Live listening. In anywhere and anytime,call the phone number in the unit,when it connects,you can live listening the sound around 5 meter of your vehicle.This means Remote Monitoring.
Overspeed Alert: When your vehicle is overspeed,the unit will send the overspeed alert to your authorized GSM number.
Anti-theft: Compatible with the original anti-theft alarm:It will send SMS alarm after your orginal anti-theft alarm warning.
Triggering Emergency Alarm: When there is a emergency happened on the vehicle,you can put on the button and the installed unit will send out alarm to your authorized numbers.
Live tracker: You can set up auto track by SMS or online positioning platform.
Why you need GPS vehicle tracker?
Personal :
1.You can control your vehicle in anywhere and anytime.It's keep your vehicle in more safe.
2.Do you want to know you wife/husband is telling lies? You can track her/his car by SMS or online positioning platform. Even,you can monitor it.
3.Someone borrow your vehicle,do not worry,you can track it and keep your vehicle under your control.
4. If unfortunately, your car is stolen, you can send SMS to cut off oil and circuit,stop running,and find the accurate position,and get back your vehicle soon.
