Hi all,
I have had a continuing problem with my cab door locks since I bought my '71 bay. I have noticed that the doors do not shut flush with the body of the van unless I really really REALLY SLAM the door shut. I usually push the locking mechanism (next to the door realease) to lock the door and close it gently, when I do this the door is not flush with the body but means that I can usually unlock the door with no poblem. However, If I slam the door shut (with some force!) I have to rotate the key back and forth in the lock for some considerable time to open it until it eventually unlocks.
However, there are occasions when I push the locking mechanism and slam the door shut (hard) and I am stillable to open the door with a few presses of the handle release button (on the outside).....what is going on, I am completely flummoxed!
Was hoping one of you technical guys out there may be able to offer a solution...I have been told to swap my nasty cheap door seals (which came with the van) for some luvely soft ones. Will these end all my locking and unlocking woes.........?
