yackaboo
Hi guys,
I'm trying to figure out my headlight dash indicator lights ( little blue and green indicators) what lights up and when..
I've just put a new wiring harness in my bus ('70' right hand drive UK bus).
With the ignition off and lights off. If I pull the indicator stalk back to flash the headlight the blue light will light up and headlight goes onto main beam, until I release the stalk which I'm pretty sure is correct.
If I pull the light switch out to the first stop (side lights) the green indication light lights up, if I pull the switch out to the second stop the green light goes out, is this correct??? if I flash the main beam or pull the stalk to switch on the main beam the little blue light will still flash or stay on ok.
Should the headlight indicator light ( green light) stay lit, in both light positions. ( pos.1 side lights & pos.2 headlights)
There is another issue as well
If I turn on the ignition and turn the lights on, the blue main beam light is on even when the headlights are on dip, If I pull the indicator stalk back to flash the headlights or to turn on the main beam the blue light goes out! If I switch the headlights back to dip beam the blue light is switched back on...
Any advice or suggestions would be appreciated.
Mike
Mike
