help with alternator wiring
This looks to be the same type as i have fitted, its an Externally regulated alternator. There should be a 3 way plug that fits onto the 3 termianls grouped together (these then go to the regulator) and the terminal on its own is the big red lead that goes to either the battery or the starter motor depending on how you feel (doesn't matter either way)
D+ to D+
DF to DF
D- to D-
All above are from alternater to regulater(one to suit the alternater NOT the genny one) connect the blue wire? which runs forward to warning light to the D+ on the reg
B+ goes to battery or starter motor
Steve
