I have a problem with a backfire, it only seems to happen on the over-run in 4th and 3rd coming down the box. I'm running a weber progressive carb and a single quiet pack exhaust. Ive checked the dwell today and its 50 degrees (smack bang in the middle of Bentleys published 42 - 58 degrees. I also checked the timing, and it also seems to be bang on. I've not had chance to check the valve clearances yet. Seems like the PO has installed the distributor drive 180 degrees out as the plug leads are all 180 degrees further around than the manual, could this cause the problem?? Anybody got any ideas?
Cheers.
Cheers.
