Interesting indeed. I’m assuming this restoration has the benefits of its own personal mortgage advisor
I’m also wondering how far you’re thinking with the body off idea. If I wanted a total resto with no resources limitation then I’d have a real good think about and ask around exactly as you are doing. Straight off the cuff now without too much thought process, I’d start with a strip down in a decent sized place where stuff / parts can be stored. One of the things that amazes me is just how much space can be taken up when you strip a whole bay down. Thinking I’d start with the doors and hatches then interior including all the panels and photograph as much as you can which is so easy nowadays. Seats out, dash out, will give you so much more space and visuals as to what you’re up against. Than perhaps wiring. Having somewhere to clean and label and box store stuff instead of heaping it on a pile. Once the internals are done and dusted and it’s still rolling, I’d go for the motor and box out and store then the fuel tank and vent pipes etc. I’d then be getting ready to fit the shell onto a rotisserie and I’d like it it chassis mounted front and rear so I could get the beam out and really get in to the nooks and crannies. So beam out and rear suspension out then you’re looking at controls and cables and stuff. Get it on the ‘spit’ and now you’re cooking. The only panels and parts coming off in my little world are the ones that need replacing. Anything that was made by VW originally and is still in reasonable shape, I’d save. Most reproduction stuff is nowhere near as good as original. By now , I’d have a shopping list as long as your arm. Every single resto is different and requires different things and usually dependent on where the van is from. Once you’re on a spit, you can really see the job at hand and can get at it too. Spare parts are usually sourced from second hand good replacements in the main. Sounds like a great approach and attitude you have to this project. Please start a resto thread as you kick off, it sounds great.
Ozziedog,,,,,,,,,have you got it yet ?
