yep,should come out,mine took a good whacking,hence the damage...have you given it a good soak with penetrating fluid (WD-40 etc) between the shaft & collar? if still no joy,try heating up the surrounding mechanism G E N T L Y with a pencil torch or the like while you tap,as the collar heats & expands it may just loosen the grip on the square shaft.
