VeeDubMan
I've pulled my front discs off with the hub and the outer bearing stayed attached to the spindle. Obviously, it popped out of it's rubber housing and the spring/wire thing that runs inside the lip of the rubber has also dislodged.
Are they re-usable? Do they have to be remove from the spindle to be re-used or can I just pop the hub back on popping the seal over the already installed bearing?
Steve
Steve
