been busy making a rotisserie/flipper to put it onto it's side as no longer be using the hoist:
added an extra tube to the top so that it is supported through the chassis aswell as the tube running under the car.
will still add extra braces to be sure.
it slides into the 2 tubes so that it can be used on either side, also going to drill holes in the top and bottom fixed tubes, weld a nut and screw a bolt to lock in place just to be sure!!
still a little welding to finish this part of the project but works awsome just as it is! 45 degrees and at 90 should have made this first!!
got it sanded back to take the rust convertor/ primer off, rubbed it with dioxidene the painted it with epoxy primer surfacer to seal it up for the trip home, get to the panel beating after all the welding is finished..
MIke
MIke
