Right im gunna put this out there and hope someone can give me a solution before i throw the lot in the bin!!! i have what i was told is a csp front beam that is adjustable and narrowed(new). It has early split king and link pin set up , again rebuilt and new. When the beam is bolted up and everything is where it should be there are at least three issues:
1. The gearshift rod fouls on the centre steering arm pinion. !!
2. The hand brake cable on the drivers side(left hand drive) fouls the steering idler arm
3. The clutch cable also fouls a grease nipple on the beam( iKnow this is easy solved)
I cannot see how I can rectify these problems unless a, the idler arm is completely wrong , i have tried to look at pictures to see if it a different angle or is stepped different than the one fitted. or B this beam has been built incorrectly.
Thoughts please
Cheers Ben
Thoughts please
Cheers Ben
