Lowering the arse!
lambrettatastic
Aug 14, 2010
52
25
I’ve recently fitted a lowered front end , and knowing I had adjustable spring plates at the back , thought this would be an easy job to get the back down a touch to level the bus out…but no!
The adjusters are fully wound out,so it looks like I need to fettle it on the splines.
So the question is having watched a few how to vids, when I detach the spring plates do I have to disconnect the brake pipe? I’m hoping not as just having fitted discs up front, I’ve had all the brakes bleed..IMG_5565.jpeg
You don’t need to do any of that with adjustable springlates. The section on the splines comes off separately - just move it round a notch and re fit. Biggest hassle will be taking the wheel off. :)
This document from Creative engineering explains exactly how to re-index just the splined portion, without removing the main trailing arm.
Just as Clem has outlined.
Last two paragraphs tell you how.
Its a job i need to do on one side of ours. someone got one side at least a spline out, so i had to balance just for now using the grubscrew fine tuners.
  • Spring-plate-fitting-instructions.pdf
    543.8 KB
