69billy said:
very easy to pull apart, just pulled the strip off each join and 5 mins with a little dremel thing i had for years and never used!! till now :lol: didn't think of casting 2 halves, but how would I join them? ive looked into stainless outers not sure I would get the curvy shape as good I don't think, but im on the case. ive asked a casting place if he cast an inner and outer mould and if it might be strong enough to press together to form a stainless shape as its quite thin to press. ill let you know
Sounds simple to remove the casing then? As for casting the fins in 2 halves, maybe you could just drill a hole at each end top and bottom, and screw together, with a tapped thread, or just use stainless jubilee type stuff you use when you fit heat proof exhaust wrap. This could also be used to retain heat, would matter if it got wet if you are using stainless outer covers.
I also saw some years back a fibreglass (with insulation) cover which fitted over the stock heat exchanger outer casing to retain heat, i bidded on it, but missed out at the last minuite as usual. You can get all sorts of fibreglass glass material to heat proof turbo's and the like...
Would be interesting to see if you can find someone to cast some fins, and stamp out some pressings. One thought i had, is that you can get stainless J tubes, now with a suitable alloy fin casting, and a stainless outer, bingo! Rust free heat exchangers.
Do you know if the exhaust tubing is straight through on a stock exchanger? I wondered if they was a "kink" or suchlike in the pipe to slow the exhaust gas down and help keep the heat around the fins? Though I think perhaps the speed the exhaust gasses pass through, any heat retention by limiting exhaust gas flow is probably small.
Also thinking, maybe you can get large bore J tubes, and do the same thing, like a "performance" exhaust system, as i understand the "boys with the big engines" tend not to use stock heat exchangers.....
Wonder if a exhaust manufacturer would do a low number run???
Anyway, 50/50 on the royalties then?
:lol: :lol: :lol:
Cheers!
Alistair
