Used the Dremel to cut the bolt off problem is the bolt is welded to the strap so I will have to cut this off as well.
Then have to do the other one [emoji38]
I have ordered a long socket so will give that a try first but I suspect I will end up cutting that one off as well.
Took out the LB and the odd ply stand that was there. I want to fit a metal or plastic holder.
The left rear corner has been repaired at some point and the filler in the corner came away easily I want to clean all this up and re seal, before re installing the LB and clamp.
Took out this strange looking device, I think it is some sort of altitude sensor.
Now having these [emoji6]
