Fraggle
Hi all
Having rebuild my busses rear brakes I decided to fit my CSP disk kit up front.......well attemp to!!
Having stripped the brakes down to the spindles as per instructions etc I discover that all 4 of my ball joints have split boots and are leaking out grease. They appear to be all ok so it's just the boots that need replacing.
Anyone done this? Any tips? How hard is it?
Next...
I tried to fit the new master cylinder as was recommended that it would need to be a disk brake unit as the original one has residual pressure valves in it thus creating drag on the disks. The new one doesn't have the the same outlets as the original so...
Can I use just one brake light switch? I guess so but wanted to check.
I will have to make up a slightly longer brake pipe as the original one won't reach.
Anyone else had these 'woes'?? Nothing easy is it but then I've learnt to expect it now so haven't got stressed just yet!!
Any help / suggestions / pics much much appreciated.
Thanks.
Next...
Thanks.
