creationblue
Hi
Spent the best part of today (inbetween watching BRFC :lol: ) fitting my spindles.
Here she is before
I had no experiance of the front end before today so started with a bit of intrepidation to say the least! The wheels came off easily enough, I rested the front beam on axal stands and started stripping the brakes, all went well, but it took me ages to hit the spindle hard enough to free the bottom ball joint! Grrrr once that was off I started to reasemble.
All went together easily enough, but after putting the drum back on i realised something wasnt right, I then noticed that there is a spacer on the old spindle shaft, so after some persuasion i fitted it to the new spindle, but all that was after I bastardised the bearing seal on the drum then noticing I had the wrong size replacment!!! So I had to put it back wthout the seal for now! Will I do any damage if I use it tomorrow without the seal or am i better off waiting till next week??
The other side was done in 10mins!! But the is always a BUT
The bottom ball joint just twisted as i tried to do the nut up, this put me bk an hour of head scratching!!!!
The wheels went on then i noticed that the bottom ball joint shaft fowled the wheel rim, so i ground off around 3mm and had to loose the lead ballancer. Is that normal?
I havnt touched the back and not sure that I need too, wot you think?
So my main concerns are, running with the seal missing, should I? and have I taken enough off the bottom ball joint shaft, im guessing that i wont get any movement. Drove it back and forwards to check for rubbing and all was ok, just not been out on the road.
CB
Here she is before
![Picture044-1.jpg](https://proxy.imagearchive.com/ebe/ebef24115775207da0092a274432c500.jpg)
![Picture047.jpg](https://proxy.imagearchive.com/825/8251c2f819ebf1c8d1b9c1b4595cc471.jpg)
![Picture055-1.jpg](https://proxy.imagearchive.com/27a/27ad09a91f68451d4fdcdfa922cbde4e.jpg)
![Picture050.jpg](https://proxy.imagearchive.com/4a3/4a33eb21fca5955e0a2a6a663c1f58d8.jpg)
![Picture052-1.jpg](https://proxy.imagearchive.com/a00/a00ee05b7b3a1c54707815726d8d3cec.jpg)
CB
