Doris
Hi all - I'm looking at having a run of these done as I am yet to find anyone who makes them....basically a repair panel for around the rear lights.
- laser cut to ensure exact accuracy (the dimensions taken directly from an original VW panel template).
- manufactured from the correct thickness metal as VW used (1.4mm,maybe 1.5mm if poss but certainly no thinner)
This sort of thing is expensive to have done for just a couple as the cost in setting up & programming the machine doesn't make it worth while.The diagram I have knocked up below is just to give you an idea of what you get,its not to scale - don't worry -the real thing will be bob on!! the piece will be approx A4 size, so there is plenty of metal to trim down and work with, which could help if part of the engine lid aperture is rusted.
price = £20 per pair - inc FREE postage & packing & primer if desired
please start group buy in the usual manner if you are interested....
e.g.
1. Doris - 1 pair - bare
2. busman - 1 pair - primed
3.
e.g.
3.
